It is currently Mon Sep 01, 2025 2:32 am
 Post subject: Westone case
PostPosted: Sun Oct 02, 2005 7:38 am
Would this fit a Spectrum MX?
Ebay link
 Post subject: don' think so
PostPosted: Sun Oct 02, 2005 11:00 am
Hey Champ amp,
I do not believe it would fit an MX...
I just went down to measure my Thunder 2 case, which is pretty well beat up. The measurements of this gents auction are very very close to the Thunder case...
I have owned guitars in the FX series which are more strat scale longer guitars vs. the Thunder... I feel that there wouldn't be enough room in the upper bout area... I tried to squeeze in a Schecter C1+ (closer to strat proportions) and the upper bought was considerable larger than the case dimensions..
So I don't think you have a match here.. But it wouldn't hurt to do some measuring and contact the seller further.. Also these cases have very generous -1" padding all around the guitar. Perhaps with a razor or exacto knife you could do a little surgery to increase your portion size..
Good luck
MikeC
PostPosted: Sun Oct 02, 2005 4:48 pm
Thanks, after eval'ing the dimensions, I believe you're right. My Jazzmaster case works fine in a pinch so far. I bet any strat fit case could potentially work here.
PostPosted: Sun Oct 02, 2005 6:02 pm
i second that- i think it's a case for a Westone Concord or Thunder- look at how narrow and high the waist is. A Spectrum/Phoenix won't fit.
Users browsing this forum: No registered users and 35 guests
