It is currently Sun Jul 06, 2025 9:10 am
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Mar 22, 2012 3:51 pm
Tune it in 5ths it will make you think differently. Sounds like you have a good handle on this one.
PostPosted: Thu Apr 05, 2012 7:21 pm
finally. pictures...
Original Auction Pictures
Today
Here some pics I found of a PCM Mandolin...
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-1.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-2.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-3.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-4.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-5.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-6.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-7.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-8.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-9.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-10.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-11.jpg
http://www.indysworld.com/guitars/Projects/mandolin/pcm-mandolin-12.jpg
PostPosted: Fri Apr 06, 2012 8:26 am
That is an amazing transformation good work.
PostPosted: Fri Apr 06, 2012 10:15 am
Pics of the same - or 2 different mandolins?
PostPosted: Fri Apr 06, 2012 12:15 pm
Two. The second section is a pcm i found pics of.
PostPosted: Sat Apr 07, 2012 5:33 pm
You know what a Plugger is, right Mick?
...here's a hint.... go look in a mirror
PostPosted: Mon Apr 09, 2012 6:57 am
:) well, using your mirror hint eliminates this...
so assuming you mean this:
"80 percent of humanity who unceremoniously keep plugging along -- balancing work, play and family life."
or this:
"vigorous promoter of something or somebody"
and NOT this:
"a dental instrument used for packing, condensing, and consolidating filling material in a tooth cavity"
8)
PostPosted: Mon Apr 09, 2012 5:44 pm
http://1.bp.blogspot.com/_4sGgoWECIeU/S ... .602.g.gif
You 'da man, Mick... :up:
PostPosted: Tue Apr 10, 2012 7:50 am
Good one Iceman - LOL.
PostPosted: Mon Nov 19, 2012 10:55 am
Yay! frets are in. Replaced the zero fret I installed earlier with a taller one. need to file ends a bit and level, then put the new binding on....
PostPosted: Mon Nov 19, 2012 2:35 pm
Cool McB! Movement on the Mandolin!
PostPosted: Wed Nov 21, 2012 8:52 pm
What about the white knob pointers? Can you tell what they would be made of?
PostPosted: Wed Nov 21, 2012 9:22 pm
i'll have to check, but i believe they are thin metal....
PostPosted: Tue Dec 04, 2012 11:48 pm
binding is on, but I've now started on the process of trimming the excess and leaving the "nubs" like this...
and yes, it is a tedious a job as it looks like it might be.... especially with the low/tiny frets I used...
http://www.stewmac.com/tsarchive/ts0131.html
PostPosted: Fri Dec 07, 2012 8:39 am
latest pics
binding install
binding trimming... yes, its a PITA, but looks really cool....
