It is currently Sun Sep 07, 2025 1:02 am
PostPosted: Tue Oct 18, 2005 10:29 am
This is a direct fit replacement, though you will need different length screws for the 2 front mounts. the new bridge only uses 4 of the 5 mount holes. Is solid brass, and lets you lower the action more than stock.
standard Electra Outlaw MPC Bass Bridge (copy of Ric 4001/4003 bridge)
the new Hipshot Ric replacement bridge
here's the Hipshot website... http://www.hipshotproducts.com/rick.htm
PostPosted: Tue Oct 18, 2005 9:55 pm
Looks like intonation and saddle adustment is much easier to set on the Hipshot. Is that what I'm seeing?
PostPosted: Wed Oct 19, 2005 11:32 am
yes, much easier, and if you look at the pics, the D & G saddles are moved way up by design, and where it's set there, was nearly perfect for intonation. much better than how the stock one was set/able to adjust to...
the hipshot has individual string height adjustments, string spacing adjustments, saddle placement adjustments.
the oiginal bridge, because of how it sat down into the tailpiece, the only way to adjust the saddles was to loosen the strings and raise the bridge up !!!
