 Post subject: X935CS wiring info
PostPosted: Mon Feb 22, 2010 3:58 pm
I'm looking for the original pickup wiring schematic for my X935cs. I had some work done on it a few years back and it hasn't been the same. The diagram needs to include wiring for two push/pull pots (coil tap and phase reverse, if I remember correctly).
 Post subject: Re: X935CS wiring info
PostPosted: Tue Feb 23, 2010 9:08 am
How bout it Pro Endorser, do you have the wire diagram for this one? That is why I prefer not to change the wiring on an already great guitar.
PostPosted: Wed Feb 24, 2010 4:28 pm
Well I've looked all over this site and haven't been able to find one on here... Remember that the X935, the Futura and the X155 all had basically the same wiring: 2vol/2tone 3 way switch with coilcut and phase push pulls. So I went out to the interwebs and found this:
You will have to read between the lines as they don't indicate the pickup wire colors and the push pulls are on the volume pots instead of the tone pots, but this should be what you're looking for B2B. Tell us if it helps (or not...), Mike.
P.S. just noticed that the phase on this diagram is hooked to the neck pickup, on all the Electras I've seen, the Bridge pickup is the one with four leads, which is necessary for phase reversal.
PostPosted: Wed Feb 24, 2010 5:35 pm
Thank you so much. I'll give it a look over.
