It is currently Sat Sep 06, 2025 8:05 pm
PostPosted: Wed Feb 06, 2008 7:37 am
Should I post them. Cavity's, back of pickups, stuff like that.
PostPosted: Wed Feb 06, 2008 8:05 am
PostPosted: Tue Aug 24, 2010 9:40 am
I'm a new member to the forum and an currently restoring an Omega X-230. I know this is an old post but it has a pic. that relates to a question I have. Somewhere along the line my X-230 had the volume pot replaced with an old pot of the wrong type. The guitar pick-up settings do not work properly and some not at all. I replaced the pot with a new 500k and wired it up like a standard les paul vol. /tone. It's better but still not right. I noticed on the top pic. of this post that there is a small (resistor?) on the vol. pot. It goes from the center lug to grnd. This was missing from my X-230. If I had'nt seen this pic. I would never have known and would forever have been wondering why my guitar won't work. Does anybody know what value this resistor (if it is a resistor) is? Any idea where I can find one? Thanks in advance and I hope someone sees this.
PostPosted: Tue Aug 24, 2010 11:29 am
I think the resistor on the volume pot is just a treble bleed circuit (helps to keep signal bright when you turn the volume pot down), although I'm not certain. Could you give us more specific info as far as "The guitar pick-up settings do not work properly"? I have a feeling there is more up here than just a missing resistor, but we can try to help you troubleshoot it.
PostPosted: Tue Aug 24, 2010 12:30 pm
So you don't think that resistor would make a lot of difference in pickup vol.? The bridge pick up seems to be ok but neck pickup is very weak or not working. All the wiring looks to be original except for the vol. pot. but I've left the 5-way switch alone (meaning I hav'nt pulled it out to inspect) I'm @ work now so Let me do some poking around inside there with my ohm meter when I get home. I don't want to waist your time. Might be a bad connection somewhere. Thank you
PostPosted: Tue Aug 24, 2010 8:13 pm
The missing resistor isn't helping in any way, but what you describe sounds like a switching problem to me. Then again, I'm not sure on an Omega what the switches in the pot cavity do, if it has the 5-way on the bout. Hafta ask the experts......who will be rolling along here anytime now......
:D
Keep asking questions, btw. We love to talk about this stuff!
PostPosted: Tue Sep 07, 2010 6:48 am
just to follow up, I had vol. and tone pots wired wrong. Also, It works fine without the resistor. Thanks for the help.
