It is currently Tue Jul 01, 2025 8:11 am
PostPosted: Wed Nov 17, 2010 8:07 pm
Guys, I know this may be a dumb question, but how do you remove the knob on the five-way switch on a MPC?
I got my X330 today and need to remove the knob to tighten the hold down nut. I thought it might take an Allen key since there is a hole in the knob, but it looks like no screw or hex head inside. Is there supposed to be a hex head that could be stripped out?
Thanks.
Electra 2236 Flying Wedge
Electra X330 MPC
PostPosted: Wed Nov 17, 2010 8:44 pm
There should be a screw. I don't recall if its a flat head or allen but my recollection is there ought to be something. I'm looking at my outlaw right now and that's got a hex in it.
PostPosted: Thu Nov 18, 2010 6:43 am
Thanks again for checking for me.
I got the knob off, just had to find the right size hex key (5/64'' is the one for future reference), only to discover someone cranked the nut on the switch so tightly that the wood body caved in slightly causing cracking to the finish...ugh! Some people just have no idea when it comes to taking care of an instrument. I guess I will need to reinforce the plastic dial ring with some stiffer backing material and maybe some felt.
Electra X330 MPC
Last edited by invisibleempire on Thu Nov 18, 2010 6:58 am, edited 1 time in total.
PostPosted: Thu Nov 18, 2010 6:51 am
That is unfortunatly a common problem with the 5 way switches. People often tighten them dow and cause cracks due to the thin layers of woods at the switch point. It will help if you do use a heavier ring material to reenforce the spot. My X330 has the same problem from it's previous owner.
PostPosted: Thu Nov 18, 2010 4:30 pm
Do you think there's enough room on the shaft of the switch to get a big washer either in the cavity or under the indicator ring? I'm thinking one of those nylon washers would be good.
PostPosted: Thu Nov 18, 2010 8:51 pm
It is a very tight fit but the nylon is flexable enough and will work. You may need to trim it a little but it worked for mine as I had the same type finish crack on my X330. I put a smaller one on the top side and the larger inside on top of the 5 way switch shaft and that seemed to work OK with the old Black 1-5 position switch on top. It is a tight fit so do not force it just trim it until it fits.
PostPosted: Thu Nov 18, 2010 9:46 pm
NICE!
PostPosted: Thu Sep 27, 2012 11:46 am
I am looking for a 5 way switch and the cream colored backing. Any ideas on where to find one for my sunburst 330?
Thanks
Users browsing this forum: No registered users and 9 guests
