It is currently Thu Sep 04, 2025 12:04 pm
PostPosted: Tue May 01, 2012 7:47 pm
I'm restoring a electra phoenix X110 and I got a split in the neck what should i get for a replacement neck? And would the neck be the same demesne as a Fender Strat
PostPosted: Wed May 02, 2012 3:35 am
The Phoenix necks changed during production. Early ones would have the truss rod adjustment at the body, and the nut at the end of the fretboard like a gibby, then they would have the truss rod cover at the headstock, but still the big brass nut, finally they would have a thin graphite nut in a slot like a Fender.
I would discourage mixing bodies/necks from different era's for mounting and intonation problems. I have also heard the pocket dimensions changed, so the fit could be sloppy or too tight to mount necks from different periods. If you can find a neck with the same features that yours has, you should be able to swap and play. Best of luck, and welcome.
PostPosted: Wed May 02, 2012 6:45 am
I think it's a 80s model it looks just like the X110VW- Vintage White the serial numbers are 58 011 and 3100750
Users browsing this forum: No registered users and 43 guests
