It is currently Fri Sep 05, 2025 7:52 pm
PostPosted: Fri Oct 05, 2012 7:27 am
http://www.ebay.com/itm/Electra-Invicta ... 3a7a606e44
PostPosted: Fri Oct 05, 2012 7:38 am
Is this an X960 or an X250?
PostPosted: Fri Oct 05, 2012 7:54 am
My mistake - x250. I thought I saw am MPC opening on rear. Must have been paging thru too fast.
PostPosted: Fri Oct 05, 2012 8:40 am
Yeah, the seller calls it everything but the correct name. It is a X250, or powered Invicta. I can't tell if the white switch is a replacement, or just a rubber cover over the original toggle. Also, I don't think the wood Truss Rod Cover is original. My favorite of the active models, for whatever that's worth.
Ask questions before bidding. Most of these Active guitars got modified, so assume its not working. Ask for pictures of the electronics. The two screws are still present on the control cover, so the preamp circuit board is most likely still present. Good luck, Mike.
