It is currently Thu Sep 04, 2025 5:27 am
PostPosted: Sat Nov 09, 2013 1:16 pm
http://www.ebay.com/itm/Gorgeous-1982-E ... 258509b193
What is going on on the back of this one? Modification or possible unit that was played around with at SLM?
PostPosted: Sat Nov 09, 2013 2:44 pm
Appears someone tried some at home weight relief :no: :no: :no: What a shame,was a beautiful example at one time-also appears to have had some wiring mods.... :no: :o :(
PostPosted: Sat Nov 09, 2013 8:11 pm
Real weird - foam filled? Whatever it is - it's pretty well totalled and there's not a chance I'd even try to restore it. Too bad..........
PostPosted: Sun Nov 10, 2013 3:52 am
Morning folks...still a beauty, till you pull her skirt up.
I was gonna say that the tooling was just too good for a home job....until I noticed that cardboard divider there. It would be interesting to be able to see the type and manner of cuts at the base of those HUGE excavations.
And....with the size of those cuts, it's gotta be lighter. Make a great wall hanger or donor for a clock kit. :look:
Might as well go ahead now with the old router and a B-bender.
PostPosted: Mon Nov 11, 2013 6:59 am
WOW. :-? :cry: And a washburn pickup. Sad, those are really high end guitars. I love mine.
Still make a great player, just take some extra attention.
PostPosted: Mon Nov 11, 2013 7:43 am
There's no way that would sounb like it should. I guess a dedicated Electra saver could try and shape a wood block to refill the GIANT holes, veneer,stain and poly. But still.....I dunno - that one is just sad.
PostPosted: Mon Nov 11, 2013 9:37 pm
The guitar doesnt matter its the pickups.
PostPosted: Tue Nov 12, 2013 7:52 am
Don't agree with that statement. You always start with the guitar. If the sound from the guitar itself is shrill, or dead, it will be quite difficult to get a good sounding guitar out of it no matter what pickups you use. Or the very least, it will strongly influence the pickups you should use. I have heard some particularly dead sounding Les Pauls for instance, that even with a lot of custom work can't be made to sound terrific. I have an exceptionally bright sounding guitar, and it required a special set of Alnico II pickups to sound great. The alnico II and overwound bridge pickup moved it into a warmer territory. It is always the combination of both. But pickups do make a big difference, but they can only work with what is there.
I'd surely like to know what it sounds like. If it has survived its disemboweling intact (doubtful), you could fill it with fitted mahogany blocks, re-veneer the back, and refinish. You'd have to be a full blown luthier to cost justify it. That is one the new electra team should buy and redo - they could use an endorser in their stable.
Man, that one has a beautiful top. Wow, people do some crazy things.
Positives:
It still is mostly an endorser
It has a beautiful top
Says it has a case
Some of the hardware looks original
Negatives:
All modified/replaced electronics
cheap replacement pickups
Totally routed out
Unknowns:
How does it sound? I know the person says it is great, but unless i really know the person, I don't trust much of what I read.
How does it play?
If you were ever looking to make it original again, absolutely no chance of that. It will never be original again.
I'd surely like to see someone on the forum pick it up. But WOW, I don't know that it would ever be worth the investment unless you could "do it yourself". I know a guy that could fix it so you'd never know. But I bet you'd have more into the repair than finding one unaltered and applying that money toward it. When he does that kind or work, it always is with EXPENSIVE vintage instruments that someone has routed out and put in a Kahler or humbucking pickups in and he fills and veneers over it and you can't even tell when completed. But the guitars are worth many thousands of dollars, not several hundred when completed. You WILL BE upside down on this guitar if you bought it for an investment. No way to come out. Almost NO WAY to get it all back to stock again, and stock value with a repair would be less than the investment. You are going to find it darned near impossible to get a set of cream MMK pickups again, unless you are very very patient and lucky.
PostPosted: Tue Nov 12, 2013 8:41 am
+1 to the above
PostPosted: Tue Nov 12, 2013 10:44 am
I have only had two Electras and i am impressed with both for the workmanship, even though my 940 needed about 40% of the top reglued, it and the 310 are well built. The thing I am not impressed with on both guitars are the pickups, even with changing the volume pot to 500k vs 50k, (someone should have noticed a zero missing), the pickups sound like a stock or worse epi, like there is a blanket over the pickup. Maybe I got two with bad pickups. I also am not at all happy with the Ducan antiquities either. I have played on a few vintage les pauls with pat sticker pickups and early stamped pat pickups so I know tone. Also use two actual 1965 fender princeton non reverbs for main amps hooked to cabs with g12h heritage celestions.
PostPosted: Tue Nov 12, 2013 11:10 am
Pickups are a very subjective thing, some pickups that are junk to me sound "great" to others! Amps are the same way. That "classic" dark, muffled, distant, canned Marshal sound from the early 80's is the holy grail for some whereas as I enjoy a very clear, full, in your face sound.
Guitar construction really makes a big difference. After pickups, proper set up, strings and pick (or lack of), that is. This is why you can have two of the "same" guitar, with the same pickups, set up, strings, and using the same pick, yet have them sound very different!
But this Endorser's gonna need some loving. I'd buy it if it were cheap enough. :D Will make a good player and project.
PostPosted: Tue Nov 12, 2013 11:12 am
Whats cheap enough?
PostPosted: Wed Nov 13, 2013 5:08 am
I don't know, maybe $150 including shipping. :D
PostPosted: Wed Nov 13, 2013 7:59 am
Agreed.
PostPosted: Thu Nov 14, 2013 12:20 am
I sent the guy a link to this post. He agreed the values not there since it's been heavenly heavely modded.
Users browsing this forum: No registered users and 22 guests
