It is currently Thu Jul 03, 2025 3:05 pm
PostPosted: Fri Oct 08, 2010 3:48 am
I'm looking for one of these rings and a brass nut for an X730 resurrection project. Any/All help appreciated. It's not a big deal to me if the numbers are worn off the ring.
PostPosted: Fri Oct 08, 2010 7:03 am
the x730 didn't have a ring. the numbers were on the pickguard....
PostPosted: Fri Oct 08, 2010 8:32 am
Thats correct - but the pickguard has hunk broken off by the switch and I figured a ring would do. Maybe I should ask if anyone has a spare pickguard they don't need. Well, thanks again.
PostPosted: Fri Oct 08, 2010 9:36 am
Brass nut from Guitar Nucleus needs a little finishing and the slots cut, but fits pretty nicely....
http://www.guitarnucleus.com/gnstore/nuts.html#elecnuts
PostPosted: Fri Oct 08, 2010 10:00 am
Thanks Redeye - that one looks pretty good.
PostPosted: Fri Oct 08, 2010 11:14 am
If that doesn't work, get a piece of brass bar stock and go at it. It will cost you very little and brass is easy to work with hand tools. I may have a 5 way switch ring. I wont get a chance to look till around Wednesday though. If I have it, it's yours for the postage.
PostPosted: Fri Oct 08, 2010 7:52 pm
Pickguard Heaven makes replacements for the outlaw....
http://pickguards.us/priceelectra.html
PostPosted: Wed Dec 29, 2010 6:31 pm
My"nut" problem has been solved. (Don't tell my Ex). I still have to figure a way to either cover up the hole in the guard or bite the bullet and have one made I guess. I've been thinking of taking a holesaw to a slim cd case back and using that or a standard LP switch ring touched up with some black enamel nail polish.
PostPosted: Wed Dec 29, 2010 8:56 pm
how big is the hole in the pg? will the pg still support the switch? the rings are pretty flimsy....
PostPosted: Wed Dec 29, 2010 9:07 pm
It's all holding together - so far. The switch does seem pretty solid. I'm probably over-reacting. I tend to get that way with my music gear. I'll try and snap a picture tomorrow. Right now there's a circle of metal tape around the switch kind of holding everything together. The silver color just offends me. :)
PostPosted: Fri Jan 07, 2011 10:24 am
Here you can see the silver tape by the switch. When I do a string change I'll take off the guard and snap a shot of the "actual damage. BTW - this has the knobs indicating it has a factory supercharge mod. Seems like I would need another X730 to A/B it properly though.
