It is currently Tue Jul 01, 2025 4:03 pm
PostPosted: Fri Nov 11, 2005 9:10 am
I'm not quite sure what this aria will be.
It is looking as a AE325. But then it should be an "Aria Mach 1" or not?
Maybe it is a kind of transistion model?
Ulf
PostPosted: Fri Nov 11, 2005 11:23 am
Since eBay links tend to litter the rest of the forums with dead links in no time I've moved this here.
It is in about the same class as the Mach I series, probably identical other than a few minor points. There again, we may debating the difference of one or two years, maybe even less. It dates to around 1976 or so (the same as my Aria SG) with the camel hump headstock (non-lawsuit). At $250 US it's already pretty steep for a mid-grade bolt neck with a good bit of wear.
