It is currently Wed Sep 03, 2025 2:34 pm
 Post subject: Re: NGD.....
PostPosted: Wed Oct 02, 2013 1:24 pm
Thanks fellas!
It needs probably 1.5mm of travel on the E/A strings away from the neck so I may get away with removing the springs but tell me more about moving the neck in its pocket, please!!
PostPosted: Wed Oct 02, 2013 2:40 pm
Put a small shim between in the inside of the neck pocket on the side of the neck pickup, and put your neck back on - that spacer will give you that much more space, a MM or so - whatever you need - then tighten the neck down. You likely will have big enough holes in the body that they won't need any adjustment. Sounds like you don't need much. A pick in there might work. So your neck will have a slight gap of a MM or two (with the shim in it). So rather than changing the angle by shimming between the neck and the screws, you simply shim the neck 90 degrees differently in the neck pocket another MM away from the bridge (inside the lip of that neck pocket). If it is visible you can try to color the ship to be close or make it black to hide it. It isn't a perfect solution, but you will need 1-2MM less travel now and likely have no ill effects. It probably would not be noticeable to anyone that does not already know about it. And your guitar should play perfectly (as long as YOU play perfectly) :D
Make sense?
It is something that takes 2 seconds to show you, but takes a long paragraph to try to explain!
PostPosted: Wed Oct 02, 2013 3:50 pm
Have you tried blocking the bridge all the way flat against the back? This may give you the rood you need without any mods.
PostPosted: Wed Oct 02, 2013 5:17 pm
That is an excellent idea and a great way to go if you don't plan to use your vibrato bridge.
PostPosted: Wed Oct 02, 2013 10:11 pm
I have the bridge set flat on the body, so no up bends - I have other guitars that will do that - but I do use the wobbler a bit, so I'm gonna try the 1mm pick tucked into the pocket; you blokes are good value, eh; thank you!!
Now... thoughts on the re-finish???
PostPosted: Thu Oct 03, 2013 6:36 am
Just a thought, if you are going to do a re-finish, maybe you should re-locate the bridge. You don't know how things are going to move in the process. It would be nice to have a little wiggle room.
How about doing a New Zealand Flag? There are lots of union jacks around as well as US flags, but NZ?
PostPosted: Thu Oct 03, 2013 12:56 pm
Rising Sun Graphic! That was an available option a couple of years after the Lady production ended... one of a kind! Not sure how a White sun on a Red guitar would look, or are you stripping it down to the wood? Best of Luck from the states, Mike.
PostPosted: Fri Oct 04, 2013 5:58 pm
I found these Gotoh tuners a while back and they look to be the same as the ones on the Phoenix X models. I havent seen them in person but they were the closest for a direct replacement I found.
http://luthierssupplies.com.au/product_ ... cts_id=695
The ad has the measurements and a drawing to the right.
Good luck,
PostPosted: Tue Nov 19, 2013 8:59 pm
Little bump here, guys...
Still undecided about the finish... I've pretty much discounted anything graphic simply because the shape is ... well, so shapely! I toyed with the idea of getting my airbrush genius to 'do' a garter around the top fin over the OEM colour...
I'm still not 100% sure what the real colour should be; the cavities theoretically should be right, but they are very, very vivid indeed, certainly compared to what the external finish was!!
Still need a pic of the jack plate, Arthur, when you're well enough, mate!! No great rush....
It's sitting on the bench... stripped and dirty...
....oh, no.... wait... thats the wife!! :D
PostPosted: Sat Feb 01, 2014 3:42 am
Right.... body is painted and ready to go - I'm refitting the bloody loom as we speak! Now, I've PM'ed Arthur but I don't know if he's about at the moment so could someone with a Lady - or a Futura/Dynasty - have a look at the jack socket plate, please as the one on mine is not OEM and is horrid. I have a sneaking suspicion that they may be non standard which will be a bastard, but if one of you nice fellas could take pix of yours and measure it as well, I'd be most grateful!
Oh, the colour, you ask?! I've wussed out and asked the painter to match what was in the trem cavity.... which he has... it looks FABULOUS!!!
Pix soon!!
PostPosted: Sun Feb 02, 2014 8:46 pm
OK, then...
... photos do not show the colour adequately, but the base coat was blood red and then many coats of pink pearl shot over the top, followed by clear coats. It looks spectacular in daylight; all shimmery!! Colour is very much like my Westone X300 Pantera...
...points with no chips!!!
... all gleaming and new!!
...installing the loom. I think that's where my short is; I shielded the cavity and didn't insulate the pots?!
... putting extra length on the pickup wires, which had been shortened previous to my ownership.
PostPosted: Mon Feb 03, 2014 6:04 am
8) Looks like the color is dead on. Great work and I will get the photo of the input jack out to you today. :up:
PostPosted: Mon Feb 03, 2014 6:41 am
Excellent job - looks new - maybe better than new.
:D
PostPosted: Mon Feb 03, 2014 6:44 am
Good job; great pics.
PostPosted: Mon Feb 03, 2014 7:10 am
Very cool! This body style has always fascinated me. Out of curiosity, how heavy would you say this one is? My Phoenix is pretty solid for its size, I always imagined these bigger models weighing a ton
----ElectraWestone red Phoenix x185
---Fender Telecaster Standard black, custom bridge
--Fender bluesjunior 15 watt tube Amp, black
-Custom made Fuzz Face, Crybaby Wah, Snark Pedal Tuner, Boss sd-1 overdrive, Boss dd-7 Digital Delay, Ross rc-3 Looper
