It is currently Thu Sep 04, 2025 12:01 am
PostPosted: Wed Nov 27, 2013 6:53 pm
Would think not, bit saw post with photos of claimed all original and appeared to have brass nut.
Thanks
Just scored a near flawless x220 cherry s/b chrome hardware with one broken switch for $148 and tax! My first Electra!!!
PostPosted: Fri Nov 29, 2013 8:12 am
I don't know for sure if it is original to that model but it is far more common to see brass nuts replaced with bone or plastic than the other way around. BTW may I be the first to say Pics Please on you new axe?
PostPosted: Fri Nov 29, 2013 8:21 am
Will post Asap...
PostPosted: Mon Dec 02, 2013 7:03 am
Found with a little research on the 'net -
Brass Nuts at WA Guitars
http://waguitar.weebly.com/brass-nuts.html
At Warmoth Guitars – several different materials for guitar nuts -
http://www.warmoth.com/guitar/necks/stringnut.aspx
Guitars Parts Resource - several brass nuts available -
PostPosted: Mon Dec 02, 2013 9:31 am
Thanks for the responses, but what I was trying to determine was whether the X220 Omega could have come from the factory with a brass nut. It seems unlikely, as plastic was cheaper, but I have seen several pictures of people's Omega X220s that have been captioned with "all original" or "stock" and they have brass nuts. I recently purchased a X220 that appears stock and has a brass nut.
I was trying to determine if anyone out there knew for sure if any X220s would have left the factory in Japan with brass nuts.
Thanks
Tim
P.S. Anyone have a source for the chrome and plastic paddle switches from the Omega series?
PostPosted: Mon Dec 02, 2013 9:49 am
The X220 shown on the model page looks like it has a brass nut. http://www.rivercityamps.com/electra/x220.php
PostPosted: Mon Dec 02, 2013 10:37 am
Right. But no way to know if that model is factory stock. Thanks.
PostPosted: Mon Dec 02, 2013 10:56 am
I've had 3 of the X220's-all completely stock as far as I could tell,all 3 had brass nuts
PostPosted: Mon Dec 02, 2013 11:13 am
From what ive seen brass what the typical nut on most Electra LP's
