It is currently Thu Sep 04, 2025 12:20 pm
 Post subject: Dead Fuzz Module
PostPosted: Sun Dec 13, 2009 10:50 pm
Time for a repair. What normally goes out on these?
 Post subject: Re: Dead Fuzz Module
PostPosted: Mon Dec 14, 2009 9:57 am
I remember some posts a while back that mentioned that the contacts can get dirty but are easly cleaned with a pencil eraser. Beyond that I would think you would nead the schematic to diagnose it. Good luck.
PostPosted: Mon Dec 14, 2009 11:43 am
I've done a repair on one module before, totally rebuilt one with all new components, and built a new one on an empty circuit board/case I picked up... the new one was a POwer Overdrive module, but I can't remember the one I re-did....
the fuzz module I have has all the waxy like stuff inside the box. as I recall, it was a royal PITA last time I did this :)
PostPosted: Mon Dec 14, 2009 7:26 pm
my experience has been that the usual cause of problems is a cold solder joint... usually at one of the capaciters.... wiggle them and see if one gives or comes loose... if so... just apply the iron to it and all should be well... if it is beyond that, then it is beyond me.... hope this helps
Live Better Electra-ly ;)
PostPosted: Fri Dec 18, 2009 9:26 pm
:up: I couldn't wiggle enything, since it's wax filled, but with my 8x lupe, I was able to see some questionable joints...
touched 'em all up, and it fuzzes fine now!
thanks!
Users browsing this forum: No registered users and 76 guests
