It is currently Mon Jul 07, 2025 4:37 am
 Post subject: MPC low battery symptoms
PostPosted: Mon Sep 12, 2005 3:01 am
I'm new to MPC's and modules and such- what are the symptoms of a low 9v battery? ALso, it appears my X910 was wired so that one battery powers both modules- is this normal? It looks like the body is routed for two batteries.
PostPosted: Mon Sep 12, 2005 8:03 am
All the MPC's are routed for 2 9V batteries; one cavity for the 9V that is actually used and one cavity for your spare 9V.
RCSBlues 8) :up:
PostPosted: Mon Sep 12, 2005 11:08 am
the modules will become intermittent, then there's be no volume at all when the battery gets low enough.....
the input jack is a stereo one, and controls the power from the battery. you always need to keep your mpc unplugged when not in use, or it'll run the battery down... (went through 3 batteries in short order, before finding the info here...)
you could always wire in a mini-toggle to control the power so you could leave it plugged in.....
PostPosted: Mon Sep 12, 2005 12:22 pm
thanks!
