PostPosted: Tue Dec 30, 2008 6:12 pm
I am trying to install Seymour Duncan pickups in a '78 Studio Zephyr for a customer (I work in a guitar shop), and I need to match the wires to the Super Magnafluxes. However, I can't seem to locate a color code or wiring diagram anywhere. I'm reluctant to go the trial and error route for fear of heating the posts too many times on the 5-way rotary switch. Does anyone have any suggestions?
Thanks,
Steve
PostPosted: Wed Dec 31, 2008 6:16 am
You could try this site http://www.matsumoku.org/guitars.html. Super magnaflux were used on Aria and Vantage guitars as well. Do a search as I remember this being discussed.
If that does not work you can test each lead when you remove it from the guitar. Test each pair of leads. Only the ground and hot from each coil will give you proper resistance. If you have a test lead (a cable with 1/4" jack on one end and aligator clips on the other) you can find which working pair leads to which coil by attaching, plugginh in and tapping. Keep notes and let us know.
PostPosted: Wed Dec 31, 2008 7:44 am
Maybe one of these URL's will help:
MPC Wiring Diagrams
http://www.rivercityamps.com/electra/sh_wire.php
http://www.rivercityamps.com/electra/slm1.php
3 Way Wiring Diagram
http://www.rivercityamps.com/electra/slm2.php
5 Way Wiring Diagram
http://www.rivercityamps.com/electra/slm3.php
RCSBlues :oops:
