PostPosted: Wed Aug 03, 2011 6:14 am
I have an early X640 and one of the three toggle switches has snapped off at the base. Has anyone else come up with a replacement? It doesn't have to look right, as long as it works without drilling the pickguard out...
PostPosted: Wed Aug 03, 2011 6:39 am
If it is either the series or phase switches, it's a simple dpdt mini switch, typically under $5 at your neighborhood Radio Shack, and a fairly quick soldering job. If it is the Active Circuit switch, that's a twelve pin monster 4pdt (quad pole double throw) switch... which you can probably find at a decent electronics supply house, but you'll need a good desoldering tool and the patience of Job to replace it... or pay a tech an hour labor to do it for you.
From memory, I believe the first mini switch (nearest the pickup selector) is the Series/Parallel switch, center switch is the Phase reverse (hooked to the bridge pickup) and the last switch (most vulnerable...) is the Active on switch.
Good luck, Mike.
Users browsing this forum: No registered users and 25 guests
