It is currently Sat Sep 06, 2025 12:06 am
PostPosted: Mon Aug 02, 2010 10:59 am
This seller obviously is not understanding how the Outlaw actually looks. He mentions that the pickguard has been cut but the guitar has not been altered.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110567395506&ssPageName=STRK:MEWAX:IT
Because it was used by a lefty I would assume that a right handed player would have to change out the nut for sure and the bridge too- yes?
PostPosted: Mon Aug 02, 2010 2:04 pm
Should be a quick fix. New Nut and strings should do the trick. You most likely can just flip the bridge and be OK. :up:
PostPosted: Mon Aug 02, 2010 7:23 pm
A close look at the photos and I noticed that there is a bunch of black electrical tape on the outside of the back panel and there is also scotch tape on the module panel.
PostPosted: Tue Aug 03, 2010 8:48 am
Given that the cavity top is shielded, he may have had problems with the components shorting on the shielding. I had that on the three way on my Workingman. I too used some electrical tape to insulate it but did a neater job of it. If it stays in this general price range it pretty much has to be worth it.
Users browsing this forum: No registered users and 49 guests
