It is currently Sat Sep 06, 2025 2:10 am
 Post subject: Abused Elvin
PostPosted: Fri Dec 09, 2011 10:59 pm
There's some real finish and binding issues going on with this one. I can't see where there's any structural damage though. The vine looks intact. The saddle doesn't look particularly high so if the action is high as the seller states, I'm thinking this might need a neck reset. At any rate this guy seems to have been more neglected than abused. If I were bidding hard for this one I'd prepare myself for some pretty expensive restoration. I'd say it's worth it. Zoom and blow up the pictures if you can. You'll see finish cracks all over and some finish ready to peel right off. A good luthier could save this for sure.
http://www.ebay.com/itm/Vintage-Electra ... fresh=true
 Post subject: Re: Abused Elvin
PostPosted: Sat Dec 10, 2011 5:18 am
Yep, looks like it was stored poorly. Probably still top $500 I'd guess. I'd take it over that finish stripped Elvin with the gnarly headstock though... I'll pass on both.
PostPosted: Sat Dec 10, 2011 11:43 am
My best guess with this one is that it was stored in an are that was not climate controled and went from hot to cold etc. This would explain the cracks in the finish and binding caused by the contraction and expansion of the wood from the changes in temperature. It can be saved by a good luthier that knows how to remove the top finish and re- apply a new one once the wood beneath is stabilized. I do not think it would cause problems in playing as is so long as it finds a good home in an environment that has constant temp and humidity.
PostPosted: Sat Dec 10, 2011 1:25 pm
As someone who has a house in Michigan that has a basement studio, I can attest to that and admit to previously making that mistake (never again)!
Record Label: SAY-10
Records & Skateboarding.
http://www.say-10.com
Band: PISSING CONTEST
Punk / Hardcore
http://www.facebook.com/pissingcontest
PostPosted: Sat Dec 10, 2011 2:15 pm
I have seen probably 2 dozen or more listings from this seller in the past 6 months or so and not one of them was for what I would consider close to a "good" condition axe at best.
There always seems to be at least one major issue at least, if not several minor ones as well.
PostPosted: Wed Dec 14, 2011 7:08 pm
Right on Mike - 511.66 shipped. Too rich for my blood.
