It is currently Thu Jul 31, 2025 11:29 am
PostPosted: Thu May 29, 2014 12:58 pm
Here are the 9 available pickup combinations with our new 5-Way Rotary & Coil Linkage System. We're including this info graphic with all Electra Invicta guitar orders and wanted to share here as well. Click the image for a bigger version.
http://www.electraguitar.com/pages/electra-invicta
PostPosted: Thu May 29, 2014 1:36 pm
Can you obtain position 1 and 5 with it set to position 3 and turn volume to zero on 1 pickup or are positions 1 and 5 a cleaner sound or more power?
PostPosted: Fri May 30, 2014 1:35 pm
Yes, you can get the single humbucker like position 1 and 5 - on position 3 with one corresponding volume turned to zero. That is one way to get there. Position 3 can be used to blend the tone with the 2 volumes, where as you're working with one volume on 1 and 5. No designed difference in output, etc....
PostPosted: Thu Jun 05, 2014 7:28 am
Wow, very versatile. Love it. :up:
I assume it's a coil tap, not a coil split, correct?
PostPosted: Mon Jun 09, 2014 10:08 am
The Invicta are Coil Split.
PostPosted: Mon Jun 09, 2014 6:08 pm
Coil Tapping is usually only done on Single Coil Pups. Tapping off between the 2 wires on a coil. These are Coil Split, seperating the coils from the humbucking config by isolating each coil.
