It is currently Sun Jul 13, 2025 2:35 am
PostPosted: Sat Aug 05, 2006 12:44 am
I got 2 modules from a buddy. Phaser and a filter follower.
Then I got an x-610 bass on the bay, and it came with a phaser, and a flanger.
both phasers work, but the others have problems.
the filter follower seems totally dead. I cleaned the contacts, but didn't help. there does not appear to be much for electronics in it, since it's so light. (revised) I just popped the top off. it appears this "module" was a display one :( there is a circuit board, and it's a Power Overdrive board...
the flanger on the other hand, is heavy, and packed full of electronics. top cover is loose and can be removed. it sometimes starts to make a high pitched noise. some component inside burned up, because there's a big black burn mark on the loose top....
