It is currently Sat Jul 05, 2025 7:33 am
PostPosted: Thu Feb 11, 2010 3:48 pm
http://cgi.ebay.com/EARLY-ELECTRA-LES-P ... 500wt_1086
$229 B.I.N. Has a big gash on the front (looks like someone glued something on there..?) also a pretty nasty crack at the nut (seller says has been repaired), some liberal chipping around the back, and no mention of a case. That being said, the days of the $200 Endorsers are going fast. If you've been thinking about getting one, pick this one up for a song, if you don't like it, you can always donate it to ElectraFest 2010 (wink wink).
March 1983 build date.
PostPosted: Thu Feb 11, 2010 5:48 pm
Thinking hard on this one,,,,,probably gunna drag my feet just long enough to loose it.
Paul
PostPosted: Thu Feb 11, 2010 6:48 pm
one of the knobs has the electra phoenix sticker on it. does that mean it has one of those "hop up" kits?
PostPosted: Fri Feb 12, 2010 4:43 am
Those SuperChargers add at least 50 Horse Power to your guitar...
There's a bunch of sticky residue on the tone pot of my Leslie West, and inside the control cavity there are a couple of resistors that I don't recognize. I thought that the 'supercharger' may be some kind of treble bleed circuit (so you don't lose brightness when you turn down the volume, which is a nice feature), but that guitar gets woofy when I turn the volume down (like most guitars). I'd love to hear Tom's take on the supercharger circuit, because I have yet to learn what the heck it does!
PostPosted: Fri Feb 12, 2010 5:19 am
Got it! :D Took proendorsers advice,not many out there in my price range-offered $195 and was accepted :hyper: Anyone have any finish repair expertise with what I assume is poly? Supercharger option? :hyper: :hyper: :hyper: sweet! Once I recieve it,I'll post pics of all the bad and good.
PostPosted: Fri Feb 12, 2010 7:09 am
Congrats man, I hope it's not too beat up for you. Could be a good gigging candidate, you know, a guitar you're not affraid to get banged up when playing out. All of the Endorsers have small comfortable necks, scooped out heals, push pulls for the coilcut/phase and this being a later version has the belly cut. The single coil switch alone makes it more versatile than a Paul, tell us how it feels when you get it in your hands finally, Mike.
PostPosted: Fri Feb 12, 2010 7:15 am
I installed the Supercharger kit on my X340 in the late 70's;
As I recollect it had new volume and tone pots and some kind of resistors / capacitors / diodes?
I have no electrician experience; I remember that I made sure that I closely followed the installation instructions; when finished a test revelaed that the volume was off at "10" and at full volume on "0", so I reversed 2 of the wires and then it worked fine;
My X330 does not have the SC kit and does not have that extra punch that the X340 does;
PostPosted: Fri Feb 12, 2010 9:15 am
:up: Congrats on a great score. Will be waiting to see the pics and description.
PostPosted: Fri Feb 12, 2010 2:02 pm
RCSBlues wrote:
As I recollect it had new volume and tone pots and some kind of resistors / capacitors?
I believe it was different value pots and caps. I may have some info somewhere, I'll look around...
Nice score on a low budget X935.
PostPosted: Wed Feb 24, 2010 4:45 pm
Did it show up yet Ozark? Tell us how you like the neck! Mike.
