It is currently Wed Jul 02, 2025 3:51 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Jan 23, 2012 11:46 pm
trying my hand at a trans burst finish on this one. black edges green middle... I need to sand and re-do the back. the front looks ... usable....
PostPosted: Tue Jan 24, 2012 1:35 am
okay, since this isn't exactly a restoration, I have some leeway with the wiring...
stock the x640N had this:
Pots:
Volume
Frequency Select
MidRange Parametric Cut/Boost
Micro-Switches:
Phase/Out of Phase
Series/Parallel
EQ On/Off
and a pickup selector...
The Artec EX3 is just a 3 setting micro-switch.
Mid-Boost (Peak)
Flat Boost (Natural)
Hi, Lo Boost (Expand)
so, I'm thinking this will be the new set-up.
V, T, T with 3 micros. Series/Parallel, EQ On/Off, EQ select.
PostPosted: Mon Jan 30, 2012 8:37 pm
uggghhhh. the bridge pup has a coil dead... hopefully I can fix it....
PostPosted: Tue Jan 31, 2012 4:58 am
Of course - just when you think you're on top of it, dead coil syndrome strikes. I hope it's just a lead you can see right away and no unwinding required.
PostPosted: Tue Jan 31, 2012 5:09 am
there was a loose / broken lead, but I had to unwind 1 "wind" and clean and solder, but to no avail...
I believe this to be the original pickup. I don't believe the neck one is however, so I may change it out for an Electra one, even though it tests out fine.
even though the bass pickup is a single coil by physical appearances (J-bass style), it appears to be double wrapped. the inner coil is fine, so I'm going to go with it as is... but wire it so it's easily replaceable (more than normal).
I'm on hold now again, because my box from guitarelectronics was missing the pots...
PostPosted: Sun Feb 05, 2012 9:21 pm
still waiting on electronics....
not exactly how I wanted the finish, but it's my first burst, and way better than it was before...
PostPosted: Mon Feb 06, 2012 5:25 am
I would be very happy if my first burst came out that well. I think a darker burst like that works well in green.
PostPosted: Mon Feb 06, 2012 8:12 am
Bursts are tough to do and trans bursts are even tougher - yours looks good!
PostPosted: Mon Feb 06, 2012 5:36 pm
How come there's a route for the truss rod at the body? Shouldn't this era have the truss rod adjustment at the headstock? Are you using an earlier neck?
The grain is a little laid back on this one, and the 'burst looks decent considering what you had to work with, congrats. Can't wait to see it strung up McB, another one saved from the fireplace!
PostPosted: Mon Feb 06, 2012 5:49 pm
Hmmm. Its the neck that came with it. Though you do point out the one area i forgot to stain. :)
PostPosted: Mon Feb 06, 2012 7:56 pm
Why would this model of Phoenix have a truss rod adjustment at the headstock? My Spectrum bass has it at the body the same as this one does. More importantly, I like the color!
Edit: Just looked at the catalogues, and all the Phoenix basses without pickguards have the truss adjustment at the body. Is there a Phoenix bass with a headstock adjustment?
PostPosted: Tue Feb 07, 2012 1:17 am
all done! got the EX3 wired in correctly, so it's actively EQ'd again using an Artec EX3 9V EQ.
went with a V-V-T knob set-up (not what I posted earlier) using vintage MIJ pots, 2 Electra, 1 other.
The switches are (new):
-Series/Parallel
-Hi-Lo Boost (Expand) / Flat Boost (Natural / Mid-Boost (Peak)
-EQ On/Off
pickup selector is Electra also.
It sounds good through headphones. Will have to test it out for real when people are awake :)
PostPosted: Tue Feb 07, 2012 5:06 am
How cool is that? I dub thee "Swamp Thang"! Great job on this one McB!
PostPosted: Tue Feb 07, 2012 8:36 am
Good job!
PostPosted: Wed Feb 08, 2012 8:18 am
Looks Nice! And the Active circuit sounds versatile from the description, enjoy!
