It is currently Thu Sep 04, 2025 12:12 pm
PostPosted: Thu Aug 23, 2012 1:16 pm
Originally had a tek glide (6 screw), but body has already had the trem route slightly enlarged and has the posts for a two post trem installed, but it apparently then needed a neck shim to get the string height correct. it appears the shim is just another neck plate...
PostPosted: Fri Aug 24, 2012 12:15 am
I used a Wilkinson 5+1 in my X195 which screwed straight in to the 6 original holes, but has yours still got the original holes or does it just have the 2 post holes? A Bendmaster Deluxe might fit?
PostPosted: Fri Aug 24, 2012 11:57 am
the original holes are still there. 2 outside ones are filled, but can be redrilled...
PostPosted: Fri Aug 24, 2012 12:59 pm
In that case, Wilkinson 5+1 will see you right!
PostPosted: Fri Aug 24, 2012 7:38 pm
The master speaks the truth. I listened and was very greatful :up: :) :up:
Users browsing this forum: No registered users and 86 guests
