It is currently Sat Jul 12, 2025 9:18 pm
PostPosted: Mon Oct 07, 2013 8:57 am
Scouting the forum for a tremolo block for my '73 Strat clone, ideally with an original arm. Threads are stripped on mine, likely because I never found an arm with the right fit -- I just got close and made up the difference with plumber's tape.
This block is short (35mm?) with a 50mm string spread. No luck in the aftermarket, as you might expect. Hoping to find something I can bolt right on. I gig this guitar pretty regularly, and want to avoid altering the tone/playfeel with a different bridge or steel block.
Any parts/prices, referrals, or advice would be greatly appreciated -- I can provide more measurements or photos, if needed.
PostPosted: Tue Oct 08, 2013 5:49 am
If you cant find a block, you may be able to drill the hole out and put a threaded collet in of the right size.
