It is currently Thu Nov 21, 2024 6:15 pm
 Post subject: brass insert
PostPosted: Tue Nov 26, 2013 9:38 am
No longer looking.
PostPosted: Tue Nov 26, 2013 10:34 am
PostPosted: Wed Feb 05, 2014 7:03 am
I realize this is a couple months old, but a brass insert (or Ingot) just showed up on the bay:
http://www.ebay.com/itm/Vintage-Electra ... 2335bbecd1
Maybe a bit pricey, but hey, when was the last time you saw one? Cheers, Mike.
PostPosted: Sun Feb 09, 2014 11:41 pm
I saw that too! Strange that it's so thick. It might be too tall to get action low enough?
PostPosted: Mon Feb 10, 2014 8:18 am
Shackleton wrote:
I saw that too strange that it's so thick. It might be too tall to get action low enough?
Hence the name "sustain block"- these are screwed into a well in the body,sits flush with the top and bridge studs screwed into it-no action impedance at all. If you have measurements,these are fairly easy to cobble out of brass stock if originality is not a concern.
PostPosted: Tue Feb 11, 2014 2:46 pm
I totally get your point on install but you would have to be really good with a router!
PostPosted: Tue Feb 11, 2014 3:14 pm
I see-so your trying to modify something else? A template for the hole and a smaller bit than the hole,and Bob's yer uncle! Be careful,routers are high speed evil little power tools :o
PostPosted: Wed Feb 12, 2014 5:54 am
If you have a drill press you could do it with the right sized fostner bit and a very sharp chisel.
PostPosted: Wed Feb 12, 2014 8:11 am
Dayn is looking for the mounting plate for what I is assume is a 900 or 300 series
