It is currently Thu Sep 04, 2025 12:53 pm
PostPosted: Fri May 23, 2014 9:51 am
Anyone have a photo of stock Outlaw (6 string) rotary switch wiring? I potted the stock pups and have them back in now, but the wiring off somehow. Phase reverse is not right. The wiring diagram doesn't jive with mine (the colors don't match), so that doesn't help. It is stock wiring, I'd only ever desoldered where the pickups connect. That's what I have wrong somehow, although I've tried several combinations it still isn't quite right.
Please help if you can, I want this thing up and running like it should be! :up:
PostPosted: Sun May 25, 2014 6:25 pm
you using the "viewed from bottom" pic?
PostPosted: Mon May 26, 2014 4:29 pm
I'd only found one, with a top level and bottom level shot. The wire colors don't jive. So I tried a different wiring combo today, put it all back together and got nothing. :no: At all. :down: Zero signal to amp. So I don't what I did. I rechecked grounds, looks fine, looks like it should work. It's so frustrating. Had it apart and together about 5 times now. If I had a shot of Outlaw factory wiring I'd be good to go. Anyone have one they would photo?
PostPosted: Mon May 26, 2014 6:25 pm
there's a pic in this listing.
https://reverb.com/item/34128-vintage-e ... ral-finish
scroll to the right...
PostPosted: Mon May 26, 2014 6:31 pm
here's the original pic... colors are labeled. be sure you have the orientation the right way...
http://www.rivercityamps.com/electra/slm3.php
however, all I did was substitute the pink for the white on the colorized version.
Users browsing this forum: No registered users and 63 guests
