It is currently Thu Sep 04, 2025 12:35 pm
PostPosted: Sun Mar 15, 2015 4:51 pm
Hello everyone. I just purchased an x350 that had been stored for years. Someone installed coil taps to it for whatever reason. The effects circuit is dead. I've downloaded the schematics and the wiring minus the added taps seems right. When I activate the switch with the battery in place there is no sound just like it does when there is no battery. Anyway, I'm a novice on repair but I'm kind of at my wits end on what/where to check. Any ideas? I'm getting juice from the battery but where it goes or stops no one knows. Thanks!
PostPosted: Wed Mar 18, 2015 6:39 pm
so you have wired it back to standard and it does not work when you flip the MPC toggle switches? Forgive me if I ask what may be silly questions, but do you have a working module installed in it? If you don't - it will shut off when you turn it on because you are turning on essentially nothing.
Users browsing this forum: No registered users and 85 guests
