It is currently Sun Aug 31, 2025 7:40 pm
PostPosted: Fri Apr 24, 2015 7:00 pm
Needs some TLC....new pots, switch and various screws. Has some buckle rash, but overall she sure is pretty!
I look forward to invoking the "no dumb questions" rule quite often while I fix her up.
Thanks to all those who helped me out earlier.
PostPosted: Sat Apr 25, 2015 1:09 pm
Was it a set neck or a bolt on?
PostPosted: Sat Apr 25, 2015 3:25 pm
It's a bolt on, but I got her at a decent price.
PostPosted: Wed Apr 29, 2015 6:18 am
Congratulations.
Try cleaning the switch and pots before you replace them. WD40 or PB Blaster may loosen the pot shafts if they're not turning. Follow up with a good electrical contact cleaner/conditioner like Caig Deoxit inside the pots to clear up scratchiness.
PostPosted: Sat May 02, 2015 2:46 pm
ultra sonic wrote:
Congratulations.
Thanks man....the electrical cleaner worked! The pots now turn like melted butter. The switch needs to be resoldered and I may be all set. I checked the neck and everything is straight. I may have one slightly high fret near the end of the fretboard, but nothing else needed except a good polish....hopefully.
Thanks for the advice!
PostPosted: Tue May 05, 2015 10:50 am
Great! Let us know how you like it as you get it dialed in.
